Ein paar Objekte ....
Also,
ich hab da mal etwas geforscht:
NGC 628 Gx const:Psc Dim: 10.2' m: 9.20
NGC 224 Gx const:And Dim: 178.0' m: 3.50
NGC 598 Gx const:Tri Dim: 62.0' m: 5.70
NGC 752 OC const:And Dim: 50.0' m: 5.70
NGC 281 C+N const:Cas Dim: 35.0' m: 7.00
NGC 884 OC const:Per Dim: 30.0' m: 4.00
NGC 869 OC const:Per Dim: 30.0' m: 4.00
NGC 205 Gx const:And Dim: 17.4' m: 8.00
NGC 457 OC const:Cas Dim: 13.0' m: 6.40
NGC 147 Gx const:Cas Dim: 12.9' m: 9.30
NGC 185 Gx const:Cas Dim: 11.5' m: 9.20
NGC 957 OC const:Per Dim: 11.0' m: 7.60
NGC 744 OC const:Per Dim: 11.0' m: 7.90
NGC 956 OC const:And Dim: 8.0' m: 9.00
NGC 221 Gx const:And Dim: 7.6' m: 8.20
NGC 436 OC const:Cas Dim: 6.0' m: 8.80
IC 1805 C+N const:Cas Dim: 60.0' m: 6.50
IC 1848 C+N const:Cas Dim: 60.0' m: 6.50
NGC 129 OC const:Cas Dim: 21.0' m: 6.50
NGC 1027 OC const:Cas Dim: 20.0' m: 6.70
IC 342 Gx const:Cam Dim: 17.8' m: 9.00
NGC 663 OC const:Cas Dim: 16.0' m: 7.10
NGC 225 OC const:Cas Dim: 12.0' m: 7.00
NGC 1502 OC const:Cam Dim: 8.0' m: 5.70
NGC 146 OC const:Cas Dim: 7.0' m: 9.10
NGC 133 OC const:Cas Dim: 7.0' m: 9.00
NGC 381 OC const:Cas Dim: 6.0' m: 9.00
NGC 581 OC const:Cas Dim: 6.0' m: 7.40
NGC 654 OC const:Cas Dim: 5.0' m: 6.50
NGC 659 OC const:Cas Dim: 5.0' m: 7.90
NGC 637 OC const:Cas Dim: 4.0' m: 8.20
NGC 189 OC const:Cas Dim: 4.0' m: 8.80
NGC 559 OC const:Cas Dim: 4.0' m: 9.50
NGC 1582 OC const:Per Dim: 37.0' m: 7.00
NGC 1039 OC const:Per Dim: 35.0' m: 5.20
NGC 1528 OC const:Per Dim: 24.0' m: 6.40
NGC 1545 OC const:Per Dim: 18.0' m: 6.20
NGC 1664 OC const:Aur Dim: 18.0' m: 7.60
NGC 1342 OC const:Per Dim: 14.0' m: 6.70
NGC 1245 OC const:Per Dim: 10.0' m: 8.40
IC 348 C+N const:Per Dim: 10.0' m: 7.30
NGC 1513 OC const:Per Dim: 9.0' m: 8.40
NGC 1023 Gx const:Per Dim: 8.7' m: 9.50
NGC 1778 OC const:Aur Dim: 7.0' m: 7.70
NGC 1444 OC const:Per Dim: 4.0' m: 6.60
NGC 1746 OC const:Tau Dim: 42.0' m: 6.00
NGC 2099 OC const:Aur Dim: 24.0' m: 5.60
NGC 1912 OC const:Aur Dim: 21.0' m: 6.40
NGC 2281 OC const:Aur Dim: 15.0' m: 5.40
NGC 1960 OC const:Aur Dim: 12.0' m: 6.00
NGC 1893 OC const:Aur Dim: 11.0' m: 7.50
NGC 1907 OC const:Aur Dim: 7.0' m: 8.20
NGC 1857 OC const:Aur Dim: 6.0' m: 7.00
NGC 7790 OC const:Cas Dim: 17.0' m: 8.50
NGC 7654 OC const:Cas Dim: 13.0' m: 6.90
NGC 7788 OC const:Cas Dim: 9.0' m: 9.00
NGC 7510 OC const:Cep Dim: 4.0' m: 7.90
NGC 7789 OC const:Cas Dim: 16.0' m: 6.70
NGC 7686 OC const:And Dim: 15.0' m: 5.60
NGC 7662 Pl const:And Dim: 2.2' m: 9.00
Vielleicht ist ja etwas für Euch Photonenjäger dabei...
Tommy
